Yealink CP935W
benf
Hi , we were looking for a conference room phone on wireless for a particular area. I see the 925s and 960s are supported , and just 'assumed' the 935 would work with one of those config sets , but curious if anyone has it working? or can recommend a different wifi model (we want to connect to the SIP over wifi in this case)
WiFi phones aren't officially supported. This phone will work fine with 3CX provided you have good wifi, but will be officially unsupported.
Reactions: YiannisH_3CX
Thanks, I figured as much. I see the 935 has a DECT base with wifi option, probably will go that route so the wifi just goes 10-20 ft to the DECT vs the office wifi
The CP935W is not listed in 3CX. If it should work, what would you choose as the model?
Thanks!
If setting up CP935W using the DECT base, you set it up in 3CX as a DECT phone using instructions I linked above in March.
If setting up using WiFi set it up with the instructions for the CP925.
Thanks! One other thing, there is no 3CX firmware, would it be the same for the CP925?
jimmy1
