Yealink phone weird when Teams Integration is activated
Alphabetic
3CX MVP
  • CX Version, Enterprise 18.0 U3 B450
  • Server OS, Debian 10
  • Is the 3CX Server Hosted and where? Cloud
  • IP Phone Make/Model/Firmware version, e.g. Yealink T54W 96.86.0.63
  • Provisioning Method: SBC
  • Trunk Provider or VoIP Gateway Make/Model, BT
After turning on Teams integration my phone doesnt ring correctly when queues are called.
The phone will ring and go off and do that in a cycle.
This happens for new queues too.
If i turn off teams integration the problem goes away.
I''ve factory reset the phone.
Im the only one set up with the integration (MS 365+Teams in extension list)
all other phones are fine.
rings fine in ring groups.
Hi Chris
It's working now.
I found that this problem went away after I ran the user script.
I had only partly set up teams integration.
