Yealink T34W Support
SaltyLager
Gold Partner
Is the Yealink T34W going to be added to the supported list on 3CX?
I was just searching for this. Hoping it will be added soon. Looks just like a T33 but a color screen so it shouldn’t be a stretch to get it supported
You guys are fast. I was searching for this as well.
Let's hope it get supported officially as I'm working on a project.
This will be great if the T34W can be a router phone also
Would also like to see support for this model. More than likely we'll be waiting for V20 to officially release for the support to be added as there are no more updates for V18 (as per recent webinar).
I think based on the series model, I don't think this can be router phone. I hope i am wrong based on the list
True, it may not. Fingers crossed basic support arrives :)
Reactions: Les Webb
Any update on this?
I just realized T34W was not on the supported list after I had ordered one.
While not officially supported, I have used the T33 template for the T34W and it works great with no issues. Just an FYI.
Reactions: CentrexJ
Do you simply select T33 while adding the phone or do you have to manually upload the template?
Stephan Eusebe
