Yealink T42S Ring Tone
Alphabetic
3CX MVP
Good Morning,
I've got a phone set up in STUN running FW 66.86.05 and i've provisioned it like this for ring tones:
the GUI shows this:
The routing in 3CX is to send external number to the extension.
When I call the number, the phone gives me some fancy melody and not ring tone 1, 2 or 7.
From the GUI, if i select #2 and change the external from ring 2 to ring 1 I get the desired ring tone. If I then change it back to ring 2 I get the ring 2 tone and the mysterious melody ring tone disappears.
Update your PBX to latest V16 if not already, ensure the phone is not using a custom template* , and check if you have any templated updates.
Ringtone inconsistency was addressed via a template update a while ago, but you will have not received it in case this particular PBX was using custom templates.
Give it a go and let us know!
Hi John,
I just installed the PBX today, it's on 16.0.8.9 with default template
Hi John,
Ok, what I thought was updated, it was not. Looks like it has just pulled some more yealink templates for me to download so I imagine this will address the problem.
Reactions: JohnS_3CX
Yes, it should do, just send a reprovision command to all the phones and give them a try :)
Finatra.us
