YEALINK T43U IP PHONE DEFAULT PASSWORD NOT WORKING
Tycoon Master
Hello All,
I have a new Yealink T43U IP Phone and I have assigned it to an extension on a 4SC 3CX pro edition. The phone is working well. The problem is that I cannot access the phone's web GUI to set some keys. I have tried the default username and password it does not work. I did a factory reset and it also did not work. Has the default username and password been changed by yealink on their phones or why is so? Anyone with an idea how to go about this
After provisioning you will find the password in your 3cx. Every change you will take directly on the phone will be reset during the night.
Reactions: Tycoon Master
Thanks. I have found it under "Phone provisioning" .
SupportRock
