Yealink T46G long BLF label fields
KauffmanOrchards
Good morning (US East Coast, it's morning!)
The Yealink T46G has a feature where you can turn on "long labels" for the 10 BLF buttons around the main display. The phone has 3 options for label length: Default, Extended, Mid Range.
In phone projects in years past with 3CX, I did this via a custom template, but we're on 3cx hosted now so custom templates are a no-no. Does anyone know of a way to enable these fields in bulk so as to avoid needing to manually touch each phone's web interface?
TIA.
Reactions: FireMedic
This is a great question. For higher-touch deployments (of the T46U, T29G, T46G, others) we generally hit the phone's UI and extend the BLF length, and that setting will "stick" thru a reprovision, as long as the phone is not reset to factory. But yes, I would love a template that would do that as well as "always show picture = no".
I'm afraid that this is not possible to enable via 3CX but as you said, we do not modify that particular setting so it should survive 3CX reprovisions.
Please update the templates to control that field natively through 3CX.
As this is not possible, all I can recommend for now is maybe have a look through our Ideas Section to see if anyone else posted this as a feature request so that you can upvote it and help push it up the list.
Stephan Eusebe
