- Joined
- Jan 4, 2018
- Messages
- 8
- Reaction score
- 0
We have a small office with 5 phones. 4 of the 5 phones are constantly losing their connection. When this happens they can call out but can't receive calls. Worst part is that this affects the main receptionist phone. When I look at the activity log I see the following:
05/25/2018 11:02:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 11:01:07 AM - [CM503003]: Call(C:220): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 11:00:43 AM - [CM503003]: Call(C:220): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:56:02 AM - [CM503003]: Call(C:219): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:55:46 AM - [CM503003]: Call(C:219): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:47:05 AM - [CM503003]: Call(C:217): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:46:57 AM - [CM503003]: Call(C:215): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:46:32 AM - x-call-control DROP: call is not found: zv3YqTLHEMk3FrN4QnAo8w..;from-tag=1c73b44b;to-tag=fdefb219
05/25/2018 10:46:31 AM - [CM503003]: Call(C:216): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:46:31 AM - [CM503003]: Call(C:216): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Cancelled/INVITE from 70.120.249.221:5065
05/25/2018 10:46:28 AM - [CM503003]: Call(C:215): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:46:26 AM - [CM503003]: Call(C:213): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:46:07 AM - [CM503003]: Call(C:212): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:46:04 AM - x-call-control DROP: call is not found: moCtd4Vk0vDJp_UOMBnkRw..;from-tag=8a11527d;to-tag=12a1dc69
05/25/2018 10:46:03 AM - [CM503003]: Call(C:214): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:46:03 AM - [CM503003]: Call(C:214): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Cancelled/INVITE from 70.120.249.221:5065
05/25/2018 10:46:01 AM - [CM503003]: Call(C:211): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:45:59 AM - [CM503003]: Call(C:213): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:45:52 AM - [CM503003]: Call(C:210): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:45:41 AM - [CM503003]: Call(C:212): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:42:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 10:39:50 AM - [CM503003]: Call(C:209): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:39:24 AM - [CM503003]: Call(C:209): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:38:06 AM - [CM503003]: Call(C:208): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 10:37:55 AM - [CM503003]: Call(C:208): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 10:22:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 10:02:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 9:42:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 9:22:50 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 9:02:49 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 8:42:49 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/25/2018 8:42:46 AM - [CM503003]: Call(C:206): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
05/25/2018 8:42:21 AM - [CM503003]: Call(C:206): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
05/25/2018 8:22:49 AM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
Rebooting fixes the problem temporarily. Would like to find a permanent fix.
This is a 3CX v 15.5 install on Google Cloud.
