Solved Yealink T53W as Router phone (SBC), not selectable in provisioning Yealink W60B Base station
aandstech
We have provisioned a T53W that will serve as router phone (on-premise) for our Privately hosted cloud 3cx server. As site will only have 3 extensions. T53W will serve as proxy for the DECT Yealink W60B base station (with 2 cordless extensions assignments). Tried to provisioned it via SBC, but not able to select the Yealink T53W SBC as the session boarder controller (not listed in drop down box option). But when I tried to provisioned another extension and a normal Yealink T42S phone to test , "Yealink T53W SBC" is available as an option for SBC.
Not sure if its a bug, our 3cx version is on latest : 18.0 (Build 908). Can someone have a look and confirm if Yealink Router phone is useable via Dect station provisioning
This is a current limitation of Update 6 - Router phones can be specified as 3CX SBC only for regular users/extensions.
They can not be used for Hotdesking, FSX & DECT devices yet. For those, you still need to use a regular SBC and configure them from the Management Console.
We are planning to improve this part in upcoming 3CX versions.
Thanks Steve, will just wait for their new version.
Just an update, updated our instance to v18.0 Update 7 (Build 296), confirmed SBC (via yealink router phone) provisioning for Dect Phones (Yealink W60B).
Finatra.us
