Solved Yealink W52P
smokie
Forum User
This phone is my nemesis, i have auto provisioned the phone smoothly but I cannot get into the web Ui, password was admin admin, but that does not work,, thanlks
aws2p has already posted this info , in your other W52P posts
it has changed since you've done provisionning, so now the good one is the one from 3CX settings, like i said previously
If you search about GUI password for W56P is located under ADVANCED --> FXS /DECT --> Select DECT base --> in FXS/DECT Details section --> Field --> Device web page password (clic on the eye to reveal)
Reactions: AWS2P
Thanks sorted salute
devo.it
