Solved Yealink W70B - V18
Artdeelight
Hi, i have an hosted by 3CX V18 PBX.
Yealink W70B is on the supported phones list.
When I want to add the base in Advanced/FXS/DECT the W70B is not listed
It seams to work with W60B Config.Do you confirm the choice of W60B?
Thnks for reading
We will check and get back to you soon.
Ok you can recheck your system within two hours from now, and the W70 should appear in the templates list as an option to choose from.
Make sure to reset your device if you had already configured it with the wrong template.
Finatra.us
