- Joined
- Dec 18, 2023
- Messages
- 18
- Reaction score
- 6
Hello 3CX Community,
I am seeking urgent assistance with an issue connecting my Yeastar TG1600 GSM Gateway to my self-hosted 3CX instance. The gateway fails to maintain registration and consistently shows "Request Sent" / "UNREACHABLE" status.
I suspect the problem lies with the Cloud Provider's Firewall, as I cannot access the security group, yet all internal diagnostics passed.
1. System and Network Context
| Component | Value | Rationale for Inclusion |
| PBX Public IP (Server) | 188.166.XXX.XXX | The server IP that needs to accept the connection. |
| Gateway Public IP (TG1600) | 203.XXX.XXX.XXX | The IP that needs to be whitelisted by the Cloud Host. |
| PBX Diagnostics | 3CX Firewall Checker PASSED | Proves the issue is external to the 3CX application and OS firewall. |
| Local Firewall (TG1600 Site) | Cisco Firepower 1120 (FTD) | To rule out blocking on the TG1600's side. |
2. Diagnostic Findings
- TG1600 NAT Setup: STUN is Enabled (using stun-au.3cx.com and the External IP Address is correctly set to 203.XXX.XXX.XXX.
- Registration Behavior: The gateway temporarily achieved Registered status, confirming correct credentials, but immediately reverted to Request Sent/UNREACHABLE.
- Packet Capture (Wireshark): The capture confirms One-Way Traffic. The TG1600 sends SIP REGISTER/OPTIONS, but receives no response packets from the 188.166.XXX.XXX server.
3. Specific Question
I do not have access to the Cloud Host's Security Group/Firewall.- Has anyone encountered issues with the 188.166.x.x IP range needing manual whitelisting for SIP traffic?
- Could you advise on which common Cloud/VPS Provider uses this IP range so I can attempt to contact their support?
