Yet again Help...
crazy-alex
ok so ive almost got my system up and running ive ran my lines from the dmarc to the system and have tone on lines.... here is where it gets sour for me.... I have a SIP truk thats working and i also have a card to the pci slot of my elastix computer with 3 lines connected to it... ive punched down correctly because ive tested with on old school phone that i have tone and the appropriate line but when i connect them to the system it isnt recognizing the 3 ZAP channels only the SIP line i created origanally... if someone could please help me with this i would really appreciate it...im running the elastix beta on there right now... is thetre a special way to have both SIP and ZAP woking together? and whenever i remove the ZAP and try to call it gives me an all cicuits are busy message... when calling the analog numbers it rings and rings endessly but never falling into my elastixs system.... Thank You in Advanced
Did you set your outbound to use the zap channels? Do you have inbound correctly configured?
yes i have an out bound route set to go through my 3 Zap channels and then my sip trunk... and my inbound is basically any DID and any CID to an ext..
cdl1
