Solved Your calls will be recorded
BCS-Tech
New User
I need to setup an auto attendant to answer incoming calls automatically and play a "Your calls will be recorded..." message and then after the message is complete, automatically connect to a ring group.
Any suggestion?
Cant find anything specific about this setup.
Thanks in advance
Any suggestion?
Thanks in advance
https://www.3cx.com/docs/manual/ivr-digital-receptionist/
look at the IVR setting. You can record any message and indicate where the calls are then received. For example, in a call group.
Yes, I understand that part, I have done that for other customers. What I don't know how to do is set the IVR to automatically transfer the call to a ring group after the recording is played. The other IVR's I have setup require the person calling to press a selection 0-9 to continue. I don't want the caller to do anything other than listen to the recording.
You could do a CFD
Alternatively...
You could do the AA and do "if no selection in x time, send to" the call queue
Alternatively...
You could do DID to a call queue, message about recording, dna on the call queue to the ring group.
Within the ivr Set Destination for invalid or no DTMF input/script timeout to 1 sec and forward call to the ring group
Reactions: ChrisC_3CX
Perfect
Hi @BCS-Tech,
If you require any further assistance or information, feel free to open a new thread!
Bluebox Global
