Zoho CRM Integration - Actual talking time
Multiconnect
Platinum Partner
Good day,
We're using the official Zoho CRM integration template for call journaling (currently on template Version 40, SupportsTranscription="true"). In the CreateCallActivity scenario, Call_Duration is built from [DurationTimespan]:
<Value Key="Call_Duration">[toint32([[DurationTimespan].get_TotalMinutes()]).ToString("00")]:[[DurationTimespan].ToString("ss")]</Value>
As far as we can tell, [DurationTimespan] reflects the total call session length — ring/queue time, hold, and any transfer/consult legs included — not just the time the parties were actually talking.
We've noticed that 3CX's XAPI reporting endpoints (CallHistoryView / ReportCallLogData) already expose RingingDuration and TalkingDuration as separate fields per call segment, so the underlying data clearly exists somewhere in the platform — it just doesn't seem to be surfaced as a predefined variable inside the CRM Integration Template engine.
Our situation: Call_Duration in Zoho is used downstream by a third-party tool that fetches the linked recording and compares its length against the reported duration to sanity-check completeness. Because Call_Duration currently includes ring/hold/transfer time, it doesn't match the length of the actual conversation captured in the recording, and this is throwing off that check.
Questions:
1. Is there any supported way to get actual talking-time-only duration into a CRM template variable (e.g. in the ReportCall/CreateCallActivity scenarios), either now or on a roadmap?
2. If not, is querying the XAPI reporting endpoints separately after journaling and patching Call_Duration afterward the recommended approach, or is there a better-supported pattern for this that we're missing?
Thank you in advance!
The duration in the CRM integration is the full call duration. This cannot be changed and variables for the other ones do not exist.
NortechTelecom
