15min Call Stops
Selimk
Hey
We currently have a strange problem on all ip phones the telephones hang up telephone calls from themselves around 15-16 minutes. The 3cx system has the latest updates also the devices. Phones with the problem:
  • 3CX Version, e.g. Standard Annual 16.0.8.9
  • Server OS, Debian
  • Is the 3CX Server Hosted and where Local
  • IP Phone Make/Model/Firmware
  • Yealink SIP-T23P
    Firmware: 44.84.0.140
    Grandstream GXP1790
    Firmware: 1.0.1.116
  • Provisioning Method: Local / VPN / STUN / SBC Local
  • Trunk Provider or Gateway Make/Model VoipQ
Ok let's look at some things that can affect this:
- Are they all on the same LAN and subnet as the PBX or are you maybe using STUN mode for some of the affected phones?
- Have you tested extension-to-extension calls too, or is just external calls that drop perhaps?
- Have you made calls using the webclient to see if they also drop at 15 mins?
- Was the system modified in any way? (ie. Parameters changed)
PS: There is no GXP1790, I guess this was a typo?
Only external calls
No webclient only ip phones
No its on the default 3CX settings
edit: GrandStream GXP1780
Ok,
Then run some tests with internal calls, and also an external with the webclient to find out.
Also you have not confirmed if any of the deskphones are possibly using STUN.
Important Note: if you find out that only external calls drop at 15 mins. then you are facing an issue with your provider, and in that case we can advise accordingly.
If it is external calls only, you might check the 3CX Activity Log to see which end actualy ended the call, was it your provider?
Do your trunk setting with "support reinvite"checked? if so try to uncheck and do a call test
Im getting these logs
06/01/2021 8:50:41 AM - [CM503003]: Call(C:3): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
06/01/2021 8:50:41 AM - [CM503003]: Call(C:3): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Cancelled/INVITE from 10.5.23.115:5060
Its unchecked still same issue
@Selimk Please read what I wrote in message #6 and run your tests accordingly
Finatra.us
