18.0.9.35 Full Installer
HelpDesk84
Good Afternoon,
Is there a full installer for 18.0.9.35 available? We are doing a fresh install from Windows Server 2016 to a new Windows Server 2022...
The only installer I have been able to find is 18.0.9.31 and it does not like trying to restore a backup from our current server.
Any tricks or tips?
Thanks!
Good Afternoon,
Good Afternoon to you,
No, there is no full installer for 3CX v18.0.9.35.
Any tricks or tips?
At best you can start a new fresh empty 3CX installation with v18.0.9.31 using your license and FQDN and ports, update this system to 3CX v18.0.9.35 and then restore the (hopefully) existing full backup.
Reactions: fxbastler
It's a catch 22 if trying to restore v18 on Windows systems. The only Windows installer available is v18.0.9.31. License activation fails on this version and license activation is needed in order to upgrade to v18.0.9.35. Installing v20 or moving to Debian are likely only options.
Just perform an inplace upgrade of Windows Server instead.
x1515
