18.0 (Build 20) Update - Asking for System Owner
GDInc
We just updated to 18.0 (Build 20). During the reinstallation/update process, it asked for a "System Owner Extension" that was pre-populated for with an extension that we do not want to use as the system owner. I continued through the install so it would complete.
Once the install was complete, I went to the users extension that was pre-populated during the upgrade process and saw its Rights > Group Membership > Default was set to "User" as it should be. I then went to the extension that SHOULD be the system owner and went to Rights > Group Membership > Default and it was listed as "System owner" as should be.
My questions are:
* Is there anything I need to do further to make sure the system owner is correct?
* Why would I be asked to set the system owner during the upgrade process if it is already set?
* Why would pre-populate an extension as the system owner but then not set it as the system owner after the update has completed?
devo.it
