Solved 2 Digit Extensions on v16?
dallaskincaid
Gold Partner
Quick question, will v16 support 2 digit extensions or does it need to be >3?
It can be between 2 and 5 digits.
14025
during install you are asked for how many digit you want to use so you 'll see if 2 digits is an option , after it's too late for change, need a reinstall
THank you so much!
Kayla Norris
