2 number ranges 1 pbx
Hans386
Good day
is it possible to run 2 x ext ranges eg 100 and 200 on the same pbx for lets say financial is 100 range and hr is 200 range and have them be able to communicate with each other? can you bind an ext range to a certain network card?
Yes.
you can specify your extension digit length (1,2,3,4 etc)
no need.
Hi @Hans386 ,
All users in a system will be able to communicate with each other. You will be able to assign them to groups which will allow them to see each others presence.
The entire system will be working off one IP Address, and not linked to individual users. It is one system after all.
Reactions: ChrisC_3CX
thanks guys appreciated
Silent_Guru
