Solved 2 SBCs sharing the same wan access
JulienM
Platinum Partner
I am in the case where a client has a headquarters site (site A) with internet access. Another site (Site B) is connected to the main site via MPLS access. It does not have local internet access. Is it possible, in this case, to add one SBC per site? Knowing that the 2 SBCs will come out with the same public ip address.
Thank you in advance
Hi @JulienM,
While we've never tested it in this configuration and therefore can't say that it'll be successful, from our side, you can have multiple SBCs behind one public IP address.
I just tested using 2 SBCs on two different networks behind one public IP address : it works without issue !
It's not really the same scenario I presented at the beginning of this post but I'm sure it should work the same way.
Great to hear @JulienM, feel free to open another thread if you require anything else!
mazet
