2019 Pricing & Licensing: Introducing the Free PRO trial
Hi Bianca, I'm not getting any option to go to v16 on the updates page
Are running your PBX on windows or linux? If windows then you need to perform a full backup of the installation and save it to a non 3CX location.
Then uninstall V15.5, download V16 and re-install it using your backup. Due to some limitations on Windows the V16 upgrade cannot be done through the management console.
If you are running Debian then make sure that you are running an updated Debian 9. The update should be available under Updates section of the PBX.
Reactions: NickD_3CX
Thanks for the info Yiannis, it is a Windows box.
Reactions: YiannisH_3CX
AshleyStokes
