3-4 seconds silence on-call startup
Rashid Raza
New User
Dear Team 3CX,
After the up-gradation of the 3CX Server from v16 to v18 and Windows Client, the following issue has been observed:
There are 3-4 seconds of silence in the stat of every Incoming and Outgoing Call (Internal/External) due to which the representatives, as well as the customers, are repeating the information/greetings which are missed at the start of the conversation.
Anticipating your response.
@Rashid Raza
In addition to the information @leejor requested, please let us know of the following to help us narrow it down even more:
• Does this issue occur on every single call or is it only some?
• Do you still get the same issue if you perform an echo test by dialing *777?
• Are all users on the same network? If not, are all affected users on the same network?
• Is the instance compliant with our hardware requirements?
EDIT: Also, Are you using the Windows App or the new Desktop app?
What is the hardware spec you're running on?
Its Google Instance
n1-highmem-4 (4 vCPUs, 26 GB memory) SSD Harddisk
3CX License : On-Premises Professional 64 SC
Users on same network
Tested with *777 got same issue delay voice on call startup
Using New Windows Native Desktop APP
Try provisioning a mobile app to eliminate any desktop software causing this issue.
Have you done any more reboots since upgrade?
Reactions: ChrisC_3CX
To add to what @kieferschild mentioned, try using the mobile app both on the same network and a mobile data connection to determine if the issue is perhaps coming from the network.
dross
