30$ SBC - nanopi neo3 as 3cx sbc
strelok89
after some fiddling around i managed to run 3cxsbc fully working on armbian and nanopi neo3
the whole board and 16GB SD card and power supply costs around 30$ including delivery at aliexpress
this is what i done to make it work:
initial setup:
flash the sd with the buster armbian release -and set the root password static ip and all what you need
3cx sbc setup:
wget http://downloads-global.3cx.com/downloads/sbccluster/3cxsbc.zip
chmod +x 3cxsbc.zip
echo "deb http://downloads-global.3cx.com/downloads/debian buster main" > /etc/apt/sources.list.d/3cxpbx.list
echo [arch=armhf] "deb http://downloads-global.3cx.com/downloads/debian buster-testing main" > /etc/apt/sources.list.d/3cxsbc.list
sudo apt --add-architecture armhf
sudo apt install systemd-sysv:armhf
sudo apt install systemd:armhf
sudo bash 3cxsbc.zip
rm /etc/apt/sources.list.d/3cxpbx-testing.list
Was it for a try challenge or do you plan to use this unsupported solution to save few $ ?
both . i going to use it for my clients . the first one going to be shipped on sunday
i don't see any problem with it ,as SBC it's pure software solution as long as debian linux supported and the architecture SBC doesn't care which hardware it runs beneath
my buisness model based on hardware renting , so if it costs me 70% less for hardware and i getting the same monthly payment for it, than it's a bargian :)
OMG are you serious? A Raspberry PI is too expensive for you?
yep 100$ vs 30$ . 100$ for SBC is too much.
on the other hand 30$ is super afordble which give it financial feasability to have more vast deployment of SBC and make the whole hybrid cloud solution more robust
Don't know where you are located but 100$ a PI is for a PI4 almost 4GB ram and 64 GB SD card with a nice cooled case otherwise it's cheaper than that.
that's the local price at Israel . buying from ALIEXPRESS is 80$ +17% customs = 94$ imported.
for a cheapPI4 2GB RAM 16GB SD , CASE and power supply
Reactions: strelok89
i can buy from france of course . how much is the prices? i don't see any? and the shipping i also couldn't find if they shipping abroad
As this is a wholesaler website for Pro only, to see prices you need an account
just a screen copy as example
how much it costs there .
pi 4 1GB RAM
standard plastic case
heatsink
16GB sd
power supply.
shipping to israel?
don't know shipping price but they say:
The website can provide international deliveries for Overseas Department and Territories and some other countries. The customer is welcome to ask Exertis Connect’s Exporting Department to get the relevant information about the carriage charges for such international deliveries.
[email protected].
