3CX 15.5 Install
WilliamFox
Help / Question
I installed Debian with 3CX V16 but I can't restore to that version. I logged in as ROOT and did the apt-get install 3cxpbx=15.5.15502.6 command and it downgraded and then it said to do a command that removed things that are not being used.
I did that but now that management console is failing to start. I have attached a screen shot of it. How can I correct this or is there anyway to erase the current configuration and let me do the web configuration of 15.5 like I did with 16 originally.
William
Figured it out.
Did the following
apt-get purge 3cxpbx
apt-get update
apt-get autoremove
To delete everything then did a
apt-get install 3cxpbx=15.5.15502.6 to reinstall and then it allowed me to reconfigure via the web.
Wecare_ITA
