3CX 20.0 Update 8 (Build 1109 Release) - Potential FQDN issues
nathanfava
Came into the office this morning, unable to get to the 3CX portal via fqdn or use the mobile/ desktop apps (apps dont show ext status however can make and recieve calls when in office)
I can get to the portal via internal IP, firewall checker passes, no changes made to network or fw rules
I can see our license automatically updated from NFRs to Enterprise Plus (ENT+) .
This update installed last night on the 3cx console
no lopnger able to ping fqdn also externally, okay internally
Are you using a dynamic IP as public IP?
DNS resolution looks OK from here, although I cannot connect to the PBX due to I assume firewall rules on your end. Can you confirm reachability status at this point in time?
ARKC
