3cx 4sc won't install in Azure
jw49
Trial User
I have been unable to install my 3cx 4sc in Azure Standard Bl2 (2 cpu 4gb ram option). Apparently they are only ARM64 cpus.
Cannot create a VM of size 'Standard_B2pls_v2' because this VM size only supports a CPU Architecture of 'Arm64', but an image or disk with CPU Architecture 'x64' was given. Please check that the CPU Architecture of the image or disk is compatible with that of the VM size.
Status: 400
The small p in your Standard_B2pls_v2 which will not work vs. the Standard_B2ls_v2 in the 3CX recommendation.
Will it is too bad that the deployment wizard doesn't give me that option
NVM i found it! Pray it works!
Reactions: fxbastler
albertpugo02
