3CX act like stun server ?
itgs
Do you know if 3CX provide stun server feature ?
If yes, on wich port the stun server listen ?
Thank you
Yes, 3CX provide STUN Server feature on default port 5060.
Thank you for reply, this is a great news for me !
So, I had to insert the 3CX fqdn in the ip phone configuration like this:
3cx.mydomain.com:5060 ?
Or it's better to use ip address ?
If you auto-provision the phone, all fields will then be set correctly by 3CX.
You can use IP-address:port if you like, but there is no need for it.
Hello @itgs
Are you using a supported device or a non supported device? If you are using a supported device you only need to follow the provisioning guide for your model. The settings will be auto applied.
https://www.3cx.com/sip-phones/
Herm77
