3CX Active Calls screen showing extension, not ring group
ccayer
I've got a Ring Group with 3 extensions selected, set to ring all simultaneously (ext 100,101 & 102) as the destination for the Inbound Rule for the primary DID. The Active Calls screen in the web interface shows Ext 102 whenever a call comes in, even though all the correct extensions all ring. If ext 100 or 101 pick up the call, the display changes to show that extension. Should this be displaying the Ring Group (800), instead of the extension? Thanks!
