3CX Advanced Cert
Dwayne Strydom
SOHO User
Any tips for the advanced test, sitting it for the 3rd time now got 22/30 the last time I sat it.
The certification is "open book" so you can any resources available to you at the time of taking the certifcation.
Have your NFR key set up and ready, the 3CX website and the training modules themselves all at hand.
Most importantly however, read the questions thoroughly as what appears to be the obvious answer, may not be so.
Hi Paul, what is my NFR key?
Hi Dwayne,
To locate your NFR key you have to log in to your 3CX Partner Portal.
Go to My Systems and then search NFR subscriptions.
Reactions: Dwayne Strydom
NFR - Not For Resale.
What is the "System" referring to at the bottom of a new Post???
Hi, we ask our Customers/Partners to select their license so we know which system they are referring to and we can assist them better :)
This information is visible only to the 3CX Team.
Hi Dwayne, we offer 2 NFR keys (Not For Resale) to our Partners. They are exclusively for our partners, not for customers.
  • Primary NFR: Partners can use it in their office, gain experience with the system, and show off to their customers what they can do with 3CX!
  • Secondary NFR: Partners can use it for testing or demos.
The number of SCs will depend on the Partner's level: https://www.3cx.com/partners/channel-partner-program/
You can find your NFRs in your Partner Portal -> My Systems -> NFR
albertpugo02
