3cx and CVE-2022-28005
Clint Reed
Does CVE-2022-28005 affect the windows apps if the server is on the current v18 3 final security patch 1?
Clint
EasyIt
The vulnerability in question was addressed in v18 Update 3 Hotfix 1 as per our release notes so nothing to worry if you are running latest already.
Thanks wanted to make sure it only affected the server side not the client apps
Yes it was a server-side issue only.
gmacinit
