3cx and GOIP8
mohamed hamed
I have 3cx professional perpetual 16.0.0.1581 linked with Goip8 GSM gateway with 8 simcards.
there are anyway to link specific extension to specific simcard .
what i mean is extension 200 linked with gsm 1
201 linked with gsm2 ....etc
only if you would make 8 gateways out of it and then target them via outbound rules...
It depends on what options the gateways has. If it allows you to dial a prefix, that is then used by the gateway to select a specific SIM for an outgoing call, then that could be used. Outbound rules could then be created (inseter that prefix) to direct a specific extension, to a specific SIM. If the gateway allows the input of a "DID" number,. one sent to 3CX, on an incoming call as a DID (not caller ID), then that could be used, along with 3CX DID routing, to send calls from specific SIMs, to specific extensions.
Came across this, not sure if it will be of help...
https://zr6aic.blogspot.com/2014/11/how-to-setup-goip-148-gsm-voip-gateway.html
hughesdouglas
