3CX and GV
sobesjm
I have followed this thread https://www.3cx.com/community/threads/3cx-with-google-voice-via-obi200.62660/page-2 to set up 3CX and GV with and OBI212. Everything is working except for outbound calls from the 3CX. The error i get in the 3CX log is Leg L:136.2[Line:10001>>1207555555] is terminated: Cause: 404 Not Found/INVITE from 192.168.1.72:5061
To me there seems to be a problem with X_InboundCallRoute. I have it set to {10001>(xx.):SP}
Any ideas on how i can get this working would be greatly appreciated.
Thanks for the quick reply.
I have looked at the thread you posted in addition to a number of others. I do not see any entries in the Obi call log. Is there a more detailed log that i am overlooking?
The only place in the obi that matches the trunk port in the 3CX is X_UserAgentPort and that is set to 5061.
Any idea what the 404 error is?
Interesting! I went through the link you posted again and made a few more changes and it is working! This time i put the IP address of the server in the URI field and now it is working. There may have been something else i missed the first time. I don't have time right now to back track to pin point the issue but i will.
I know, that in the past, people have used some different settings than what I have used, and it still worked, so obviously not every setting is necessarily needed, or it is a bit "flexible". As long as its working, that's the main thing.
I'm not sure if this is related but the OBI dashboard now shows 3CX as being paused. I haven't seen that before. The setup is still working.
nizammoktar
