3CX and IOS Issues
Tahir
Installed a 3CX system using PBX Express, all is working perfectly fine with just an odd issue with multiple IOS Phones. When the 3CX client is installed on the iPhone and an incoming call is received, if the user tries to pickup the call it just accepts the call and says 'Call ended' and but the user calling continues to ring out.
The logs tend to show the following:
10/29/2018 5:08:25 PM - [CM503003]: Call(C:1): Call to <sip:[email protected]:5060> has failed; Cause: 408 Request Timeout/INVITE from local
If we use an Android phone and the 3CX client, there is no problem it works perfectly. Anyone seen this issue and know of a fix or what may be going wrong? It has been tested on multiple devices, and the issue occurs specifically when the phones are on 3G/4G, if connected to WiFi they work fine. Also, it is using the 3CX Tunnel.
I have also had to uncheck, 'Enable PUSH for smartphones', 'Re-provision phone at startup', Use 3CX tunnel for remote connections'. If I dont, then even when the desk phones are disconnected, or if I disconnect the broadband to the site (this also disconnects the SBC) the extensions say lit to green, and its strange because even when the 3CX client is uninstalled from the iPhone's the extensions remain green.
Any insight on the above would be appreciated.
Device Info
Phone Model: IPHONE
Generation: 3G/4G
Firmware Version:
Jailbreak: NO
Cydia Installed: NA
Issue Info
Handset: IPHONE
Contacts: EXCHANGE (No problem with contacts)
Connection: 3G/4G
Server: External OVH
Unlucky. The root cause appears to be with a corrupt SIP packet, missing [ and ] around the IPV6 address, in the Via header. Hopefully someone at 3CX will pick this up as a bug soon....
zipman
