- Joined
- Aug 26, 2020
- Messages
- 8
- Reaction score
- 0
I have a [Twilio] studio app that basically just sends a short response to our members and then a Zapier app takes over to handle the logic for their request. That part is fine. I'm trying to add a "help" keyword that will then push the SMS request to our 3CX system where our staff can then respond to the member. I don't think this is possible but thought I would check.
My first thought was to enable the webhook routing in the number in Twilio, which I know works fine, the issue is that the staff are then inundated with SMS messages that are just querying the automated system (the zap) and 90% of them they don't need to be responded to. I don't know of a way to interrupt the process if a condition exists and not send it to the webhook unless a keyword triggers it or, alternatively setup a rule that dumps all incoming messages unless a keyword is discovered. It seems inbound rules are only for voice. Am I stuck
Any thoughts?
Any thoughts?
