3CX Android App (Beta) Receives UI Facelift
MichaelB_3CX
3CX Team
Staff member
3CX Support
We’ve revamped our Android App’s UI! This Beta release brings modernized elements, an enhanced user experience, as well as tweaks to make the screen more intuitive and functional.
Always there: Avatars & Status indicators​
Screen views have been updated to always show the avatar and profile indicator. Ideal for faster intera...
Looks good, nice work.
Icon on bottom left corner is labeled 'Team', but on Desktop/Web client it's labeled 'People'. It would be nice to keep this the same for consistency.
It will be - what you compared right now are the beta mobile vs stable desktop versions.
Hello, will you make possible to give call through GSM and not data ?
With OpenIP, we have choice to phone 3CX extensions number through GSM communication but we can't use 3CX application because it makes call by Data.
As emergency call, make a number in 3CX application and dialing through GSM signal ^^
@AymericOctis
The 3CX client is a Voice-over-IP application, therefore internally it checks for available network (IP) interfaces provided by the device then tries to connect. What kind of hardware transport is behind that IP interface... it doesn't matter to the client, can be WiFi, GSM, bluetooth, LAN cable, radio, infrared, RS232, whatever.
@Vali_3CX How do you call emergency services ? Not by IP handling ? May we just exclude more than one emergency number ?
Technically, it's identical to calling a phone number directly from a html page in a browser on the mobile, only the number is an emergency one.
But I dont get your point about excluding emergency numbers - you can entirely turn this feature off in the 3CX client settings. Can you provide me the exact case (country code) for which you want to exclude some emergency numbers?
From a mobile with an OpenIP SIM Card, we can call 3CX extension number without data connection, it's an option called Revolution.
So, if we can manage choose to make call from 3CX app through 2G/GSM connection, it's like we have an unlimited DECT cover. Where standard call works, we can do 3CX call without wifi ou LTE quality problems.
@Michael B
@Vali_3CX
It would be very helpful if you cloud add a little dot to the icon of the 3CX app, so that I can see immediately if I’m online or offline. Right now, I need to open the APP to see if I’m online. And to be honest, I sometimes forget to get back online after a meeting and that would be very useful to see it without opening the APP
cvanderzwan
