3CX Android App call out works but shows blank dialer
atharris214
New User
I am confused of what is going on. Brand new android phone - TMobile REVVL 6 Pro. 3CX works for all out going and incoming calls on a registered line.
When user (aka me) calls out, it brings up a blank non 3CX dialer and I have to press back button to see the dialer from 3CX - screenshots is attached. You will see the main dialer, then I dial, press call, this blue screen comes up and I have to press back to see the last screenshot. This is not what happens when I was using the iOS version so I am pretty sure this is a bug or setting issue that I need help with.
Any ideas?
Hi @atharris214 ,
Thanks for your feedback.
I would try to disable Telecom API and give it a shot.
Hamburger Settings > Settings > Advanced > Audio options > Disable Car/Bluetooth support (Telecom API)
RJenkinsROCK
