3CX Android - Exit without Push option vanished
Yes,
good to see this option back.
I think, If users must manually disable and enable the account, chances, that you miss/forget to enable again are much higher. The option to close the program and deactivate, but automatically enable incoming calls after next launch makes simply life easier.
Exit - Ignores PUSH has been added back to the app.
Please download the latest version.
Thank you! It's great to see a company actually respond to user feedback promptly like this. This will really help all of us support our users (and keep them from uninstalling the app).
Thank you so much...just made my life easier.
Exiting without PUSH will ignore PUSH notifications/calls until the next time the app is started. Improvements to this will be available in one of the next several releases.
Thank you for bringing back this option!
Thank you, app can now be used again by our users
Thank you, exit without push is an essential user tool.
Thanks for listening to your customers. That's what is great about 3CX.
This seems to have been removed from the latest version again (I'm on beta ).
I hope it will be put back before main update but is there any chance of keeping it in beta versions also otherwise the beta is unusable for me (and many others based on the number of comments this generated ) .
Please update to the latest beta. Exit - Ignores PUSH is there.
DejanMDS
