3CX Android v18
timmehb
Hi Guys,
Is there any update as to when we can expect v18 of the 3CX app. We're awaiting a number of critical bug fixes and it's been 4 months since the last app update! We are aware of the beta, but that has a further bug of no incoming caller ID when using the Keep Active Function.
Also, can you let me know if the Keep Active function is going to persist across reboots? What would be just super, would be a setting that can be set on the PBX on a per extension that enables/disables the feature.
Thanks.
We'll make the official Play Store release next week.
Regarding the "Keep Active" feature, the issue with Caller ID not being shown has been fixed and will be available; the one regarding persistence across reboot will require more work and will be available later.
@timmehb Please note that the app has just been released.
Finatra.us
