3cx APP - Android compatibility
EmanueleC
Are push notifications fully supported on Nokia or Motorola branded phones, especially with Android 11 or Android 12 "go edition" operating system?
I'm looking for cheap smartphones that support the 3cx app and push notifications. Some advice?
Hello @EmanueleC Android Go, officially Android Go Edition is not supported, it is a stripped-down version of the Android operating system.
The 3CX mobile app runs on mobile phones with Android 8 or higher
You may also find our guide on how the 3CX mobile app works for Android devices.
ARKC
