3CX app Call
miziwise
If the app is used to make a phone call and the employee is distracted while entering the number and does not enter it in full immediately, the app will continue to dial. Can't this be set to clear the input?
Any solution
Hi @miziwise If I enter a number using the dialer and I got distracted for a while, the app does not send the call to the pbx, and the app will not clear the input after X time, it must be done by the user the same way he uses the dialer on a smartphone.
albertpugo02
