3cx app issues - could not connect
Bilalikram
Forum User
hi , once i scan QR code , my application is keep on connecting mode
5001 , 5090 is opened
its a new 3cx setup
pls advise
its a new 3cx setup
pls advise
How is it hosted? On-prem, cloud or Hosted by 3CX?
Does the firewall checker pass?
It is hosted on premises
Port opened: 5060, 5090, 5001, tcp/udp
Please advise how to run a firewall check
It is hosted on premises, public ip is ..
Do not share your FQDN and IP here.
To run the checker, go to Dashboard > Firewall (middle block), and click "Start".
Bilalikram was using this utility, meant to be run at the remote site where the STUN phones are installed:
"This is useful for when the 3CX Firewall Checker within the Management Console succeeds all tests, but remote clients still present issues." https://www.3cx.com/docs/firewall-checker-client/
That is not very useful in this case, as it is meant for a different purpose.
@Bilalikram
1. send a welcome email for your extension to your email
2. put the phone on 3G/4G mode - Turn OFF WiFi
3. Scan the QR code from the email, not from the management console
..and tell us if this worked
Thank you for the support.
I have another issue, + is not recognising in outbound rule.
For locally calls daylight with + not working, which is important as everyone saves direct with + ,
Thank you
Thank you
Best to start a new post in the General section for this
Please see below firewall testing
Dude, REMOVE that screenshot ASAP and change your extension password!
I was able to connect to your webclient with these informations.
How to remove it please
How can u remove please
Already removed
Thank you very Much
DejanMDS
