3cx auto-answer,
Mohamedseliem
Forum User
hi everyone,
I have few questions so bear with me please:
- is there a way to enforce Auto-answer for the agents ? is auto-answer status (enabled/disabled) trackable ? I know from the desktop app it's doable but the agent can change it
- best queue ring-time can be set ?
- when queue is empty, does the call drop immediately or waits ?
- what is "mean time" in call reports ?
- the total login time, does it include the talking time or shall i add it to login time ?
thanks a lot
hi everyone,
Not officially. You could hack the IP phone itself to auto-answer via a custom template if required though. If only using a softphone you could have a scheduled task hack the settings XML every x seconds.
Please provide more information on this question.
Meaning no agents logged in? It goes right away to DNA (Destination no answer)
Mean time should indicate average time, but you will have to confirm / wait for someone else to chime in.
thanks a lot
Should include all time the agent is logged in, including on a call. Again, you will have to confirm / wait for someone else to chime in.
how that can be done ? for the softphone i mean
any tutorial ?
our queue ring-time is set 10 sec to switch between the agents through round-robin strategy, would that affect ABN rate or not ? shall i increase or decrease it ?
our queue is 801 Extension, sometimes i find a call from it to one of the agents ? what could be the issue ?
801 is calling 444 for example
any tutorial ?
3CX for Windows application stores it's settings in %appdata%\3CXPhone for Windows\3CXPhone.xml. The AutoAnswer option is either 0 for no autoanswer or 1 for autoanswer.
<AutoAnswer>0</AutoAnswer>
You'll have to write your own script to update it, then have that run on a regular basis.
ABN like how your telephone service provider bills you? Switching between agents (polling) has no effect on that.
More details needed, but the Q calls a person in multiple situation - you should check the extension statistics report for more details, or enable verbose logging and use the logs in 3CX.
CBHMIA
