3CX Azure upgrade
eds.pare
We kinda limit the access to our 3CX azure servers that must all be coming from our public IPs.
is there a port or ip we need to whitelist to do the upgrade? we are in azure v16.
Thank you.
Regards
To perform the upgrade, all connections are outbound from the host.
To fetch the pre-fight check, the upgrade process and the the Debian repositories it self it needs to load the upgrade from
the upgrade fails using direct.
Reactions: ChrisC_3CX
fngl
