Solved 3cx binlog viewer 15 error
LariFari
bin log viewer 15 crashes.
3CX Interface
An exception occurred Form1 Error: Die SplitterDistance muss zwischen Panel1MinSize und Width - Panel2MinSize liegen.
OK
How can it be repaired?
Hi @LariFari
Try it on a different computer and see if you have better luck.
I can confirm it works for me on Windows 10 (1903)
Are running it on a PC with a very low resolution screen ?
Hi JohnsS_3CX,
after installing .net updates and rebooting the problem went away.
Screen resolution is at 1920x1200 and I could use binlog viewer before.
Perhaps .net was messed up.
Yeah that's possible. Glad to hear it was resolved!
For the record it requires .net framework and Visual C++ Runtimes
Kayla Norris
