3CX broken after forced Debian 9 upgrade
jakorsme
My 3CX iphone app would just crash on launch.
A updated 3CX client app appeared in iphone App Store. I installed it.
It came up on the phone alright, but said it had disabled all incoming calls until I upgraded 3CX (what????)
Since 3CX is already current, I figure it must be requiring the Debian 8 to Debian 9 upgrade the 3CX console keeps nagging about displaying a notice to do.
So I follow the doc to upgrade from debian 8 to 9.
The Debian upgrade goes fine and the server is up on debian 9.
However 3cx services never start and I have no idea why.
Now I'm without a phone system and thinking I'm going to have to lose my existing 3CX configured system and start all over with a new 3CX. I just don't have time for that.
the latest ver 16 only worked on Debian 9 , not Debian 8.
do you know what version you where running ? Version 15 worked on Debian 8
do you have a valid backup, if so you maybe able to restore the system using this backup. using the Debian iso image, and within the wizard select restore from backup https://www.3cx.com/docs/upgrading-pbx-v16/
Reactions: AWS2P
No backup, I didn't expect an os upgrade to kill an application. But it is what it is.
I thought I was on 16, but logs are saying 15.5.
I just ran - /sbin/3CXStartServices and it seemed to create a bunch of service related files. Now the 3CX Management Console login screen comes up but I get a red "Server Error". 3CX Web Client also comes up, but I get a "502 - OK" error (both upon trying to login.
root@3CX:~# systemctl start 3CXPhoneSystemMC01
Job for 3CXPhoneSystemMC01.service failed because a timeout was exceeded.
See "systemctl status 3CXPhoneSystemMC01.service" and "journalctl -xe" for details.
root@3CX:~# sudo 3CXStopServices && 3CXStartServices
Created symlink /etc/systemd/system/3CXEventNotificationManager.service → /lib/systemd/system/3CXEventNotificationManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXEventNotificationManager.service → /lib/systemd/system/3CXEventNotificationManager.service.
Created symlink /etc/systemd/system/3CXCfgServ01.service → /lib/systemd/system/3CXCfgServ01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXCfgServ01.service → /lib/systemd/system/3CXCfgServ01.service.
Created symlink /etc/systemd/system/3CXMediaServer.service → /lib/systemd/system/3CXMediaServer.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXMediaServer.service → /lib/systemd/system/3CXMediaServer.service.
Created symlink /etc/systemd/system/3CXPhoneSystemMC01.service → /lib/systemd/system/3CXPhoneSystemMC01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXPhoneSystemMC01.service → /lib/systemd/system/3CXPhoneSystemMC01.service.
Created symlink /etc/systemd/system/3CXPhoneSystem01.service → /lib/systemd/system/3CXPhoneSystem01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXPhoneSystem01.service → /lib/systemd/system/3CXPhoneSystem01.service.
Created symlink /etc/systemd/system/3CXIVR01.service → /lib/systemd/system/3CXIVR01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXIVR01.service → /lib/systemd/system/3CXIVR01.service.
Created symlink /etc/systemd/system/3CXQueueManager01.service → /lib/systemd/system/3CXQueueManager01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXQueueManager01.service → /lib/systemd/system/3CXQueueManager01.service.
Created symlink /etc/systemd/system/3CXCallFlow01.service → /lib/systemd/system/3CXCallFlow01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXCallFlow01.service → /lib/systemd/system/3CXCallFlow01.service.
Created symlink /etc/systemd/system/3CXSystemService01.service → /lib/systemd/system/3CXSystemService01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXSystemService01.service → /lib/systemd/system/3CXSystemService01.service.
Created symlink /etc/systemd/system/3CXTunnel01.service → /lib/systemd/system/3CXTunnel01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXTunnel01.service → /lib/systemd/system/3CXTunnel01.service.
Created symlink /etc/systemd/system/3CXAudioProvider01.service → /lib/systemd/system/3CXAudioProvider01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXAudioProvider01.service → /lib/systemd/system/3CXAudioProvider01.service.
Created symlink /etc/systemd/system/3CXHotelModule01.service → /lib/systemd/system/3CXHotelModule01.service.
Created symlink /etc/systemd/system/multi-user.target.wants/3CXHotelModule01.service → /lib/systemd/system/3CXHotelModule01.service.
Job for 3CXQueueManager01.service failed because a timeout was exceeded.
See "systemctl status 3CXQueueManager01.service" and "journalctl -xe" for details.
Job for 3CXCallFlow01.service failed because a timeout was exceeded.
See "systemctl status 3CXCallFlow01.service" and "journalctl -xe" for details.
Job for 3CXSystemService01.service failed because a timeout was exceeded.
See "systemctl status 3CXSystemService01.service" and "journalctl -xe" for details.
root@3CX:~#
root@3CX:~#
root@3CX:~# journalctl -xe
Jun 11 19:28:50 3CX systemd[1]: 3CXCallFlow01.service: Main process exited, code=killed, status=9/KILL
Jun 11 19:28:50 3CX systemd[1]: Failed to start 3CX PhoneSystem 01 CallFlow Server.
-- Subject: Unit 3CXCallFlow01.service has failed
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit 3CXCallFlow01.service has failed.
-- The result is failed.
Jun 11 19:28:50 3CX systemd[1]: 3CXCallFlow01.service: Unit entered failed state.
Jun 11 19:28:50 3CX systemd[1]: 3CXCallFlow01.service: Failed with result 'timeout'.
Jun 11 19:29:05 3CX systemd[1]: 3CXSystemService01.service: State 'stop-final-sigterm' timed out. Killing.
Jun 11 19:29:05 3CX systemd[1]: 3CXSystemService01.service: Killing process 8017 (3cxSystemServic) with signal SIGKILL.
Jun 11 19:29:05 3CX systemd[1]: 3CXSystemService01.service: Main process exited, code=killed, status=9/KILL
Jun 11 19:29:05 3CX systemd[1]: Failed to start 3CX PhoneSystem 01 System Server.
-- Subject: Unit 3CXSystemService01.service has failed
-- Unit 3CXSystemService01.service has failed.
Jun 11 19:29:05 3CX systemd[1]: 3CXSystemService01.service: Unit entered failed state.
Jun 11 19:29:05 3CX systemd[1]: 3CXSystemService01.service: Failed with result 'timeout'.
root@3CX:~# systemctl status 3CXCallFlow01.service
3CXCallFlow01.service - 3CX PhoneSystem 01 CallFlow Server
Loaded: loaded (/lib/systemd/system/3CXCallFlow01.service; enabled; vendor preset: enabled)
Active: failed (Result: timeout) since Thu 2020-06-11 19:28:50 PDT; 1min 40s ago
Process: 8230 ExecStart=/usr/lib/3cxpbx/3CXCallFlow -p /var/run/phonesystem/3CXCallFlow01.pid /var/lib/3cxpbx/Bin/config.json (code=k
Main PID: 8230 (code=killed, signal=KILL)
Jun 11 19:27:05 3CX systemd[1]: Starting 3CX PhoneSystem 01 CallFlow Server...
Jun 11 19:28:35 3CX systemd[1]: 3CXCallFlow01.service: Start operation timed out. Terminating.
Jun 11 19:28:50 3CX systemd[1]: 3CXCallFlow01.service: State 'stop-final-sigterm' timed out. Killing.
Jun 11 19:28:50 3CX systemd[1]: 3CXCallFlow01.service: Killing process 8230 (3CXCallFlow) with signal SIGKILL.
root@3CX:~# sudo lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 9.12 (stretch)
Release: 9.12
Codename: stretch
root@3CX:~#
When doing apt-get upgrade
Updating from Version 15.5.15502.6
Loading global scripts...
Loading instance scripts...
Loading instances...
Npgsql.NpgsqlException (0x80004005): Exception while connecting
---> System.Net.Sockets.SocketException (111): Connection refused
at Npgsql.NpgsqlConnector.Connect(NpgsqlTimeout timeout)
at Npgsql.NpgsqlConnector.RawOpen(NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlConnector.Open(NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlConnection.<>c__DisplayClass32_0.<<Open>g__OpenLong|0>d.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at Npgsql.NpgsqlConnection.Open()
at Updater2Db.UpdateInfoExtractor.LoadInstances()
at Updater2Db.UpdateInfoExtractor.Init(Func`2 configRepository)
at UpdaterNx.Program.DoUpdate(String scriptFolder)
at UpdaterNx.Program.Main(String[] args)
dpkg: error processing package 3cxpbx (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
3cxpbx
E: Sub-process /usr/bin/dpkg returned an error code (1)
tdzski5
