3CX cloud phonebook problem with Cisco SPA504G
bytesolutions
Hi everyone.
I have a customer, who owns many Cisco SPA 504G, authenticated to a 3CX v.18 server in cloud.
The customer wants to keep these phones, and actually everything works fine, everything except 3CX's shared phone book.
The 3CX server supports a phonebook.xml file in https protocol only, while SPA504G phones only accept xml url in http protocol (when I enter the URL with https it goes into error, if there is a way to get https URLs accepted tell me please)
To help me, the software developer in the company has recreated a phonebook.xml file on a local server under HTTP protocol. The address book is now correctly opened by all ip phones, and we are able to browse it and incoming calls are associated with contacts; Unfortunately, however, the "search" function key is totally missing, by opening the personal directory of the single ip phone the "search" key is present, while opening the shared directory the key disappears. I guess we need create a code that activates the search among the contacts (the phonebook.xml of 3CX has this function active) but I don't know what the code or the instructions to be given in the xml file are.
Can anyone give me some advice on this please?
I have installed a 3CX instance on a Windows pc, in order to open the folder containing cisco_phonebook.xml and analyze it better. In the forum I read that this file is contained in C: \ ProgramData \ 3CX \ Http \ Interface. The problem is that on my instance the "Interface" folder is not there. Actually even the link http://192.168.3.101:5000/provisioning/j5l3owaex7ucqou/cisco_phonebook.xml that automatically provides in the provisioning XML does not work.
Could it be that I didn't create the folder?
I am really very grateful to you
Thank you all
Access to remote 3cx servers is restricted to https traffic only, this is for security and can not be changed.
L'accesso ai server 3cx remoti è limitato al solo traffico https, questo è per sicurezza e non può essere modificato.
And this is clear to me. For this I have recreated the phonebook.xml file on a local server. It works, but the contact search function is not managed. It is evident that some instructions are missing from the xml file
martin1176
