3CX commandline wizard with XML - FQDN issue
ThomasV2
Platinum Partner
Hi All,
We are using 3CXWizard on debian to install PBX's for our customers.
The process is automated by using the XML answer file.
Recently (i guess since the last update) the numbers for choices in the answer "Select your preferred domain suffix" have changed.
Netherlands was always 22, now Austria is...
My question: Is it possible to keep this XML as static as possible to not disrupt automation? Or is this documented in the change logs? If so, where can i find the latest XML example file with correct question/answer pairs?
Thanks in advance!
Thomas
The ID in the XML shall not be used as a static value. Better to parse the cloud domains and search for the keyword you are looking for. When we add or remove domain the sort index might change.
[email protected].
