Solved 3CX Conferencing
sevenvoip
Getting this error in the Activity Log when an external caller tries to dial into the 3CX Conference I created...
I've researched for about an hour now through the forums, but can't seem to find an answer.
Hello @sevenvoip
Does this only happen when calls are hitting the conference server? Do calls to normal extensions work?
Correct. Calls to normal extensions work without issue. My inbound rule is setup to go to extension 700 (Conference Ext). If I edit that inbound rule and tell it to go to a regular extension, it rings without issue.
What PBX version are you running? Does calling the conference extension from another extension work? Are you using the default telnyx template or did you make any changes to it?
I will mark this as resolved. I had my DIDs entered in 18001234567 when it needed to be +18001234567. Sorry for all the confusion.
Reactions: NickD_3CX
awan05
