Solved 3CX Configuration API Access
QssIT
Hi There
Looking for some clues on why my API user is set in the web admin console as a "owner" and when logged into the API the connection returns it is connected as a "user"
I have a working connection on a Enterprise 16SC
Mirrored those settings to an Enterprise 8SC
On the 8SC I get 403 errors and the API connection Role is "user"
Is this a license issue or is something broken? I checked with 3CX Support but they don't offer anything for API
Any thoughts would be appreciated
IP Console Restrictions in Admin->Advanced->Console Restrictions?
Thank you for checking in on this one so promptly
This is indeed the issue, I did not see in the API config that a console access restriction would affect the API permissions available.
It is logical but would have expected a total no connect when console is restricted, but we are on our way now.
ARKC
