3cx configuration tool - possible to go back to command line from the web browser ?
digitalMD
Is it possible to back to the command line after (1) is chose ?
I don't have access to the certificate file from the browser.
aren't the certificates located at the path above ?
Are you using a custom FQDN or a 3CX FQDN?
Reactions: bitn2
Then you're doing it all wrong.
Download your PEM files first to your local PC (not the one that's on 3CX, that's a different cert file. You should use your own SSL you bought.)
Then use the web installer to upload your backup and install your certificate files. It will put them where it needs them. Don't try to set this up manually.
Reactions: KyriacosS_3CX
AssurancePartners
